跳转到主内容
修复你的物品
维修的权力
商店
Repair and disassembly information for the second-generation iPhone SE, announced and released in April of 2020.
43 个问题 查看全部
Device restarts when the progress bar appears when trying to restore
Hi,
I have an iPhone SE 2020. Today it got stuck in a boot loop suddenly, I tried to restore/update it while in DFU but everything goes normal until the progress bar for the update appears on the screen then the phone automatically restarts to DFU. Itunes says error 4013. I also tried to do it with Wondershare Dr. Fone but the same issue persists.
Please help me solve this issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Thank you for your help & time guys
完成的
添加一条评论
1个回答
最有帮助的答案
There are two things to unpack here. First, if the phone got stuck in a boot loop suddenly, what happened before that. Was the phone dropped, repaired or came into contact with water recently? Secondly, are you attempting a full DFU Restore or Update?
iTunes Error 4013 is usually NAND related. Seeing as how this happened after an attempted Restore/Update, there is a strong possibility that the memory was corrupted. Was the device pretty much at it’s memory capacity
这个答案有帮助吗?
得分 2
评论:
No it was not dropped or contacted water.
I have tried both restore and update with the same issue.
The device is 128GB, there is still 50GB free.
完成的
Is there still a waranty?
完成的
Yes but I work in a remote area and won't be able to get to apple store before 2 weeks from now and it is the only phone with me, so I have no choice but to try to fix it myself
完成的
The only real option right now is to keep trying to Restore via DFU mode. Unless you can micro-solder and have ready access to a NAND programmer, this will not be a DIY repair.
完成的
@refectio well I guess I'll keep trying
完成的
添加一条评论
添加你的答案
Ahmed S 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 41
