跳转到主内容
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
Disc won't insert all the way
So I just recently bought a ps3 cecha01 model from eBay. When I try to insert a disc it either doesn't take it at all or, when I fiddle with the gears a bit, it takes it almost all the way. The disc never fully makes it to the spinner and the gears are working fine (I think). Could it be the IR sensor or would this just be a gear issue? I'm trying to avoid buying a new unit.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Possibly a bad motor in the drive unit, a bad sensor, or crud in the gears/rails. It depends on what “it takes it all the way” means — are you pushing the disk in? Does the drive close on its own with no disk? If you’ve taken the drive unit apart and thoroughly cleaned and lubricated the moving parts, it might be time to look at a replacement.
这个答案有帮助吗?
得分 0
1条评论:
Yeah the right side of the drive seized up. I decided to just go for a replacement
完成的
添加一条评论
添加你的答案
Micah Hett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 138
