Samsung Un82mu8000 horizontal line
Update (10/24/2020)
Update (10/24/2020)
Un82mu8000 horizontal line how to fix
jerry carrera horizontal lines are almost always a panel error. You can check the the driver board. That is the board where flat ribbon cables from the T-con board connect to. There are small ribbon cables that enter the panel. Carefully check to see if you can find some obviously damaged component on that. The board itself cannot be replaced by the DIY’er due to how the ribbon cables are fastened (bonded to the panel). Best advice I can give you is that you can try and press on the ribbon cables (if you have any on the side of the panel) and see if that changes anything. Otherwise the only option is to get used to that line. No fix other than a new panel which is most likely going to cost more than a new TV, if it is even available.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 87
