iMac 27-Inch (Mid-2011) A1312: dodgy GPU, inverter and fans gone hyper
Hello,
I’ve been wondering how much longer my iMac 27-Inch "Core i5" 2.7 (Mid-2011) A1312 can keep going. Then the other day the screen went black. First time it’s played up.
Looked it up: seems GPU was a recall issue so good that I got 9 years out of it.
Did the shine torch thing – all was black.
Did the PRAM and something similar. No change.
Hooked up a spare Acer display in the Thunderbolt – all good so I can carry on working.
Q1. If Acer works does that mean the Mac’s GPU was fine all along and it was inverter board? Or does the Acer have its own GPU?
Called a repairman. He replaced the GPU with presumably a used unit and at the same time hoovered out a shed-load of dust.
(The iMac casing did get quite hot – much cooler now with dead screen. I used to hoover the vents periodically but never occurred to dismantle and clean the insides.)
Repairman restarted: still no screen but now all the fans came on flat out.
He checked for dislodged temp sensors and connections. (I think he had to lift the logic board to get the old GPU out. Did not watch it all).
He could not find any so suspected a blown inverter board and, with now GPU fixed, explained the dead inverter was setting the fans off. Could be wrong, but this sounded more like he was looking for excuses caused by careless hoovering or reassembly.
The fan issue was hacked by downloading TG Pro Manual fan controller as clearly having the fans flat out was not an option. If the iMac goes to Sleep the fans kick off again.
Q2. Would a blown inverter set the fans off?
One thing I notice on the TG Pro menu is that various GPU components read warm.
GPU Diode 45
GPU Heatsink 42
GPU PECI 31
I don’t know what any of these things are but does that mean GPU is working OK and the fault is downstream?
Fyi the 4 CPUs are low 30s °C and the hottest thing on the menu is the Platform Controller Hub Die (47).
The coldest is LCD Monitor Proximity 19° C (room temp?) – or the Case: 28°C.
Also, is this menu of some 2 dozen item temperatures a list of heat sensors?
And if one was not working would it not read oddly low?
Thanks for any ideas.
