跳转到主内容
A2115 / 2020 / Processors from 3.1 GHz 6-core i5, up to 3.8 GHz 8-core i7. Released August 4, 2020.
44 个问题 查看全部
Aluminum Scratch/Mark Below Brand New iMac Display?
Hello! I just received my new 2020 27" iMac customized with a 1TB SSD. When I unboxed it, I noticed below the screen bezel where the display meets the aluminum housing that there's this rough area that sticks out and is reflecting the light. It's really noticeable, but so far seems to be cosmetic as it's not affecting the display.
Could this just be due to a bad display assembly process? Is there a recommended way to lessen the look of it? Or just deal with it the way that it is? It would be a hassle for me to return it as I ordered it customized online and the Apple Stores near me have limited availability.
Any thoughts would be appreciated! Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Time to bring the system back to get the display assembly replaced if the issue is within it.
If I didn’t know any better I would have guessed someone had opened the system up in correctly.
Refer to this guide to see what I mean iMac 英特尔 27 英寸 Retina 5K 显示屏更换 Note how the top edge and sides are released nothing is done along the bottom edge.
Keep in mind the clock is ticking! The longer you wait the more likely they will think you did try to open the system.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Liam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 328
