跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1645 个问题 查看全部
KitchenAid - krfc704FPS00 - won't cool
My KitchenAid - krfc704FPS00 stopped cooling in the fridge and freezer Sept. 9th. I’ve had the appliance people out twice so far with the last one coming yesterday. Still not cooling.
First time they replaced the compressor, didn’t work, said that there was head pressure that burned it out?
They’ve replaced the compressor, a board, the evaporative coils, took out all the freeon, put in new freeon, he was fusing things with his blowtorch. I had hope, but this morning nothing, not any cooler.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did he replace the fan in the freezer
If the fan isn't working, it won't
Did he check the thermostat
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Faust Gorham 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 229
