跳转到主内容
微软第三代Xbox游戏机于2013年11月22日发布。
727 个问题 查看全部
Installing a blank internal hard drive
Hey guys! The internal hard drive of my Xbox One broke completely into the point that it is unreadable by the Xbox and my PC. It was a simple hard drive failure, with the hard drive ‘reading hand’ somehow lagging, which caused the magnetic structure of the hard drive to lose all data. This means I cannot transfer any data from the old drive to a theoretical new drive.
Can I simply buy a blank new hard drive, punch it in the Xbox One and turn it on? Or somehow use a flash drive to install a new OS on the hard drive? Is there any way I can make my Xbox One work again?
Thanks in advance :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You can’t expect it to work like the PS4, Xbox One is not designed with internal HDD user self-service in mind.
Although it is possible. There are utilities exist to format blank hard drives exact like Xbox One factory default, then download the correct version of the OS image and manually put all the files there, then the console should be ready for a recovery boot and you can further recover it to actual factory default.
这个答案有帮助吗?
得分 1
2条评论:
Cool, thanks for the answer! Can you name a utility I can use to format the hard drive? And where can I download a correct version of the OS?
完成的
Something like this:
https://www.pcsavants.com/tech-tips/xbox...
Not sure if it is still relevant or up to date, but you can try.
完成的
添加一条评论
添加你的答案
Harri Huttunen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 66
总计 2,297
