跳转到主内容
Repair guides and support for a wide range of boats.
11 个问题 查看全部
Need outboard boat motor repair?
Need to do maintenance on my 150 Yamaha Outboard motor? No manuals to do these repair or no way to do repairs up to having a Schooled Technician.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
This question was migrated from https://meta.ifixit.com/Answers.
完成的
Ronnie Reed give us a complete model number etc. and let's see what we can come up with. something like LF150 etc. otherwise it is very difficult to assist you with this.
完成的
添加一条评论
1个答案
If you need a repair, tell us what isn’t working. If you are doing maintenence, about the only routine maintenence on these is to change the oil and oil filter and replace the gear lube in the lower unit. Old Turkey is right about needing the numbers off the engine. There should be a sticker on the outside of the motor below the engine with this info.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ronnie Reed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 191
