跳转到主内容
The ice maker works for a few cycles then quits.
Where is the reset button on my unit? Model KSF26C6XYYOO.
The ice maker works for a few cycles then quits. New water filter, new water inlet valves already and tube is not stopped up. Pulled the control board off the end of ice maker and looked for bad connections. When i put it back in it ran for 10-12 cycles.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@govols082859 Your model doesn’t have a reset button on the ice maker. Sometimes I’ve found that the reason it starts working after I’ve removed it to inspect it, then put it back in and it works awhile, is a worn gear that slide into place with all the movement.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
govols082859 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 31
