Stopped making ice after a few months,
I have a French door bottom drawer ice maker. Accidentally left the freezer drawer open a crack one night and magically the drawer ice maker started working again. Stopped making ice after a few months, so I took everything out of the freezer and left it open a crack when I go to bed. In the morning, I push the reset on the bottom of the ice maker until I hear the ding sound and it works for a while. Is this process bad for the freezer or fridge?
3条评论
The bottom I/M works great but after a couple of weeks a little water starts coming out from under the fridge. If I turn to ice off the water stops. I don’t even bother with the upper I/M too much trouble.
由 valeriedimeco 完成的
Bottom I/m makes ice just fine but after a couple of weeks water starts leaking out from under the fridge co I turn to ice off and the leaking stops
由 valeriedimeco 完成的
Samsung French Door Refrigerator- RFS267AARSXAA- due to other issues - I have replaced the water inlet valve and ice chute gasket - those problems solved. Also, made sure that everything was cleaned out from back of refrigerator. When I put the ice maker back in it will fill and freeze the ice but will not dump it. If I disconnect the plug-in for the ice maker it will dump and refill within a few minutes. It’s not the ice maker because I bought a new one and same problem. It just won’t dump.
Any ideas? Thanks!
由 rmgarcia01 完成的
