跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
How can I fix the dent on the aluminum without replacing the display?
I had recently dropped this Mac from half feet above the ground onto concrete and there’s this minor dent that happened just on the front, close left to the area where we open the lid. To make matters even worse I used a nail trimmer and rubbed on it to make the thing even, but it created a hole and I can see it every time I close the laptop. It’s little annoying. Found no solution on the Internet as to what I could do. Mostly they tell me to replace the body when taken to Apple store. It’s costly as the panel has the display attached to it. Is there a way I can just apply some thing to close or fill the dent?
Help appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
are you able to provide a picture of the damage? 在已经存在的问题里加入图片
完成的
@zmentz I just posted the image to the original question. I also had done some rubbing to the dent to make things even, but it created a hole.
完成的
Ok interesting. So you can try and use "epoxy putty" ive used it before on my old HP laptop, but as of now that seems like the best solution to try, but ill keep looking into it and update any further research if that doesnt work
完成的
I was advised to use a Silicone Sealant as opposed to a epoxy putty as it's currently not available at my place. Do you think it can get the job done?
完成的
添加一条评论
1个答案
最有帮助的答案
us skin to cover the dent because if you cover the dent you will need to paint it and the macbook is not painted it coated using electricity and you not able to match the color
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Vijay Kanta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 265
