跳转到主内容
The Canon Rebel T6i is a popular, semi-professional grade Camera with a 24.2 MP sensor designed for any user. Also known as the EOS 750D and the EOS Kiss X8i, this guide is meant to aid in the repair of a few common problems that may occur during normal use.
20 个问题 查看全部
My DSLR doesn't recognize my Flash
My Canon 750D / T6i doesnt recognize my external flash
I use Godox TT685C it worked on my Friend’s DSLR
I think The Problem is the Hot Shoe Maybe
*The little piece of metal that hides the Screws is missed.. but it doesn’t affect*
i tried Godox V1 and TT860 but also didn’t work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would start by cleaning the contacts with whatever alcohol you can find.
Update (10/04/2020)
Try:
- Update camera firmware
- Reset all settings (maybe some setting is making your flash not work)
If that doesn't help you will have to open your camera to take a look at the connections/wires, for what I see in the picture it has a lot of moisture/dirt that may have creeped inside.
https://youtu.be/hpnWB3Yzcac
Here is a disassembly guide
这个答案有帮助吗?
得分 0
2条评论:
Still doesnt work
完成的
Can Someone help me fixing this problem please ?
完成的
添加一条评论
添加你的答案
Ahmed Mohamed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 630
