跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Nintendo Switch won't charge
Hi, my son’s Switch won’t turn on or charge. I replaced the battery, and in doing so, damaged the SD card reader, so I replaced that as well. Since the new battery came with some charge, I can be sure it is not a display issue, as the display worked, but on connecting the Switch to the official charger (directly - no dock) there was no indication that it was charging. I have attempted to charge it over several days with no effect.
Other than the battery, what other replaceable points of failure could there be? And how would I best test them to isolate the issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Not sure if you need help anymore but do you have a multimeter handy?
完成的
添加一条评论
1个答案
Here is a list of components that can cause a Switch to not charge:
Battery
Charging Port
Charge Chip
Various other chips, diodes, resistors, capacitors, etc. on the motherboard
As Raffi said, you would need a multimeter to check to see if these were bad. You would also need a hot air station, flux, solder, and a soldering iron to fo these other motherboard-level repairs.
Another thing you could do is to replace the motherboard. However, a new motherboard will cost about $180.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Sharpe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 580
