跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1046 个问题 查看全部
Apple Pay, "Hold near reader", what should I replace?
Hi there, just recently I had run into issues with Apple Pay on my first gen SE where it’s no longer recognizing terminals and saying "Hold near reader”. I suspect it’s a hardware issue just due to the fact on how it stopped working. I’ve read some posts already on this site but am unclear on what I should get repaired.
I had my power button replaced due to that being damaged so maybe check the flex cable? Can that be replaced?
Would the NFC chip need replaced? CAN it be replaced? Actually, can it be upgraded too? :o
thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The NFC conductor wire is part of the power button flex, check if that is missing, broken, or screws and contact clips on both ends are loose/misplaced.
You can’t replace the NFC chip as it is security/payment related. If Apple were to allow it to happen, Apple Pay credit card fraud would be all over the place.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the info, I’ll take a look at what you suggest. If that is the cause is there anything else I should be checking for?
I assumed that about the chip it self but I thought I’d ask, thanks!
完成的
添加一条评论
添加你的答案
Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 428
