跳转到主内容
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
156 个问题 查看全部
Device won't turn on
My daughter came to ne with her DSi XL and said it will not turn on. Indeed when you press the button it flashes then turns off. It will turn on when a game is loading, but turns off immediately after. We have removed the battery, cleaned the contacts and fully charged it. There are no rattles in the case and everythign else seems to be in order. I am guessing it is the power board, but that is just a guess. has anyone else had this experience. Alos it has been dropped, but it had worked for a while after that.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
5条评论
I bought the dis 3years ago and it worked for couple of months
完成的
My dsi xl doesn't turns on I'm just waiting for someone to sell me a charger
完成的
My dsi xl has been broke since 2014 i think
完成的
Have you charged the dsi?
完成的
If i try to turn it on, nothing happens, it wont even flash
完成的
添加一条评论
2个答案
已选择的解决方案
Mark, if you are sure that your battery is charging and holding a charge you may want to check the LCD's and the cables, especially to the top screen. Those do have a tendency to break." If the top LCD ribbon cable is damaged or not connected properly the blue power light will turn on briefly and the bottom LCD screen will flash on very briefly when the power button is pressed. If the bottom thin LCD ribbon cable is damaged or not connected properly the blue power light will turn on briefly and the top LCD screen will flash on very briefly when the power button is pressed." Let us know what you find out. Good Luck
这个答案有帮助吗?
得分 8
8条评论:
Thanks! That makes sense. If the screen is at 90 degrees to the console I can push and hold the power button. It powers up and runs, but when I let go it quits. If I push it back one notch, it won't work at all. I have to leave on business, but when I get back I will take it apart and investigate your theory.
完成的
Sounds good, have a safe trip. Let us know how it turns out.
完成的
Thanks.... That got it. It was one of the connectors on the ribbon..... Lets see how long it last. Thanks for your help....
完成的
Great job, good thing you got it working. All the best to you....:-)
完成的
Hi, I have the exact same problem as above. How do I replace the ribbon?
完成的
显示更多的3条评论
添加一条评论
The DSI Fixer Hey if you want your back buttons on your DSI to work all you have to do is blow on them with all your might.Then what you have to do is open it up and see if it works and boom it works again and if it doesn't work sorry. I am telling you this because it worked for me and it turned it on and made it work even better then before.
这个答案有帮助吗?
得分 1
1条评论:
Wow, thanks! Didn't know that, will try!
完成的
添加一条评论
添加你的答案
Mark 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 62
总计 55,870
