跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Weirdest issue with lock button
Suddenly my lock button only works for turning on the phone, waking and clicking 5 times for emergencies. Lock and turning off doesn’t doesn’t work - and the weirdest part is that the phone can’t even lock if i use the assistive touch function (software?)
I’ve tried reseating everything inside, as well as resetting settings in software.
Yes…the auto lock is set to 30seconds
thank you !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like a base-level issue with the software. Have you used a computer to reset the settings and software, or only by selecting that option in the phone settings?
I would recommend following this guide on iFixit to put your phone in DFU mode, and then using your computer to install a fresh copy of the firmware from the bottom up. That would be the most likely fix.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Oscar Velay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 31
