跳转到主内容
修复你的物品
维修的权力
商店
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
1790 个问题 查看全部
Boot Loop no display
Hello Forum,
I have a problem with my Iphone 7 (qualcomm)
So i had a no service issue which i repaired (Kind of) and after replacing BBPMU i had to do a restore, on the phone i saw imei number so probably everything was soldered just fine.Till that moment device was turning on properly. So i tried to restore my phone using 3uTools and Itunes, and finally i got error -1 , and my phone was stuck on progress bar under the apple logo, nothing happened for few minutes and i decided to turn it of holding buttons. Then my phone was just looping to recovery mode, and on 3utools i clicked on EXiT recovery mode, and after that my phone is not turning on at all, on Bench power supply i can see after holding power on 60mA jumping to 200mA and turning off, and process starts again, if anyone has any idea what is the solution i’d really apericiate any kind of help :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
1个回答
最有帮助的答案
You will need to re-ball the baseband CPU but being the Qualcomm model the baseband will probably be shorted internally. If it is you could try burning the short out but it doesn’t have a good success rate.
If the keypad brings up the IMEI you might just get away with re-balling the BBCPU.
这个答案有帮助吗?
得分 1
评论:
the problem is with device not turning on couse of some other problem, not PPBMU, when i changed the chip everything was just fine
完成的
ill check if tigris is shorted on 5V0Usb
完成的
@msac1ek The baseband PMU is not the baseband CPU which I am talking about. The power readings you supplied are a signature fault for the baseband CPU.
完成的
Are you sure that its Just it ? , Just died after not succesful restore. After hours of working properly
完成的
The problem is there is no internal short on the board , When im turning on something Just doesnt work, ill get some measurements in few days , ill get better power cables and usb amp and voltage meter, and everything will show up. Im thinking something might died when i interrupted doing restore when it was unsuccesful. any idea what could die? Nand or something ?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Msac1ek 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 58
总计 58
