跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
474 个问题 查看全部
iPhone 11 FaceID not working - but EVERYTHING looks fine
Hi there,
I’ve bought iPhone 11 (not Pro) which had cracked display - I’ve updated it form iOS 13.7 to 14.0 - I’ve replaced it with good one but not Apple - I’ve programmed (with iCopy Plus) it to have TrueTone which I have now (but still message it is not genuine Apple) - and I am unable to setup FaceID
Most of the time it is stuck on “Move Lower / Higher” sometimes FaceID not Available - sometimes when trying to set up FaceID it looks like it cannot catch autofocus and gets blurry (when in selfie mode - it never happen).
“Red Light” present (I was able to capture it using other iPhone camera) - selfie photos are sharp - proximity sensor is working - automatic brightness working - I’ve updated to iOS 14.0.1 - same nothing.
Many people reporting they have same problem after iOS 14 - but I do not know if that happen because of iOS 14 as I STUPID done update before replacing LCD.
Please see photos of my sensors
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Did you replace the selfie camera assembly? On the iPhone X-present, those are NOT user-replaceable with the ability to keep Face ID.
这个答案有帮助吗?
得分 0
1条评论:
Noup - I did not - and if I would (or someone would) I think I would get "FaceID not working" or something like that - but sometimes I got no message "FaceID not available" for very long time when I try to setup
完成的
添加一条评论
I’m having the same issue too, except I haven’t got the “FaceID not available” yet. It just tries to focus over and over, moving in and out of blurriness. It tells me to position my face in the frame, even when I am. Let me know if you get an answer.
这个答案有帮助吗?
得分 0
1条评论:
use macbook camera to see if you will see faceID "red" blinking light - if yes - it is good thing
完成的
添加一条评论
添加你的答案
Bart 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 465
