跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314 个问题 查看全部
When I turn on the unit,why does it immediately turns itself off?
It turns on just fine and the light is green. It charged just fine. But, it will immediately turn itself off and even holding the on button won't work. What could be wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
mamaconfused, it is possible that this can be caused by either that the connection is loose that holds the top screen ribbon cable to the board or that the ribbon cable to the top screen is damaged and will require replacing.Your DS power light will flash briefly but is is not going to boot because of these issues. Of course make sure that your battery is holding a charge as well, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
mamaconfused 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 837
