Why is my battery charging but not increasing
So I bought a water damaged iphone 7 plus that’s been turned off for 3 months, i found a shorted capacitor right under the ear piece speaker ( only sign of water damage in the entire iPhone) so I removed said capacitor and the iPhone booted normally, I restored it through iTunes to get the previous owners data off and it all went well, signed in with my iCloud account and started testing the iPhone and then it started shutting off after like 4 minutes of use ( I charged the battery using a lithium ion battery charger up to 10% to make sure the iPhone turned on and at this point had the iPhone plugged in this whole time but the battery went from 10 to 5) so I thought I should let the battery go through a few cycles to start working normally again but it’s been 24hrs and the phone is still at 5% but it went to 4% then 3% then back up to 5% so I really don’t know whats the problem I tried the hard reset but no luck someone please help me im desperate
1条评论
I didn’t replace the battery and I don’t have the tools to see how many amps it’s drawing i can probably cut a cable and put my multimeter on it to check and i will check 3utools now also in settings it says that the battery has been to 100% in the last 24hrs and its not been, when I check the battery health it just stays on the loading screen until the phone restarts
由 rayan essolh 完成的
