跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
375 个问题 查看全部
Can I do a front glass only replacement at home?
I don’t want to spend a lot of money on a new display when my one works perfectly fine, the only issue I see is needing a OCA LCD Glass Vacuum Laminator Machine but theyre expensive, is tehre any way to do it without them
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
You have a premium phone that cost a thousand plus dollars when it was new and there’s a reason for that and apple certainly didn’t use cheap parts to make it. Because that phone uses an OLED panel, glass only repair on them is near impossible without thousands of dollars in special tools you’d be better off replacing the whole screen assembly like every other cellphone repair shop would do, such as myself. It’s unfortunate that you broke your device but by trying to cheap out on the repair isn’t going to make it any better. However, you can do the repair yourself and if you really don’t want to pay a whole lot to fix it, you could order an LCD replacement screen rather than an OLED. But there are a few caveats to using an LCD. It has increased energy draw compared to OLED, which can impact battery life and you do run the risk of damaging the display connector because it’s not designed to handle such a high current draw. You can order them from mobile sentrix for around $85 plus shipping and tax but it doesn’t include tools.
这个答案有帮助吗?
得分 2
添加一条评论
If you need to ask, you can’t do it.
If you want to do this kind of DIY repairs to save money, you’ll usually end up spending even more than buying a brand new phone.
Unfortunately above rules are very common in Apple DIY repairs.
这个答案有帮助吗?
得分 1
添加一条评论
Or find a shop that will do the job for you, I think if you let them do only glass refurbish on your original screen it won’t cost you a arm and a leg. Glass only repair is possible for around €75,-.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mosminecraft4 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 325
