跳转到主内容
Water flow minimal. Won't make coffee or clean.
My Impressa A9 water flow has slowed to minimal since changing my filter again. This happened once before. Sent in for cleaning/repair $$$ but do not know what they did to fix it. No longer moves enough water to make coffee or clean. Sounds like pressure builds up but no water flow.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Problem solved by removing grounds tray and cleaning residual grounds from behind vertical grounds trap door. Use your fingers. Then remove water tank, remove filter, refill water tank with max hot tap water, replace water tank with hot water, replace clean grounds tray and run rinse coffee system, Followed by brew coffee with same hot water and NO filter. Water flow and normal function did return. Remaining Hot water was poured out of tank, filter placed back in tank and Tank filled with cold water. Tank reinstalled then “Replace filter” cycle was run with old filter in place only to run filter rinse cycle. After all this I am Back to normal coffee brewing!!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bill TURNQUIST 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 24
总计 565
