跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1198 个问题 查看全部
Wifi and cellular data won’t connect
I have an iPhone X that can accept and make calls, can see the cell network, and log into the WiFi network, but cannot connect online with neither WiFi nor cell data. If I set the phone as a hotspot, the devices that connects to it can use the data online. Somehow, the phone just won’t connect. I’ve made sure the antenna is secure. I’ve reset all network settings. Hard reset. I’m not sure what this might be.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
This problem usually occurs on the X’s after a drop. There are two parts of the logic board that are sandwiched together. The bottom board which has all the RF components communicates with the top board through solder pads. When it suffers a drop it can cause cracked solder balls which become oxidised. If you have checked the antennas I think you will need to separate the boards and re-ball the pads.
这个答案有帮助吗?
得分 2
1条评论:
This makes perfect sense, and how I want this to be wrong... haha. Thank you!
完成的
添加一条评论
This worked for me.
If you are connected to a wifi network, you are using the wifi. Are you stating that your cellular data only works when it's enabled but not connected to a wifi network? Do you see the 4GLTE icon at the top of your screen? Check Settings>Wirleless&networks and ensure the state of the cellular network is enabled. If it is and the cellular data is not working you can try to reset the network information by opening up your dialer and entering ##72786# and tapping yes. This will take you thru the activation steps once more and you should have your cellular data working once more.
这个答案有帮助吗?
得分 0
2条评论:
It sees and connect to the WiFi network. It sees and displays the cellular network too. As a hotspot enabled device, I can connect a different iPhone to it and use the internet to get online but the original phone itself gives me errors on both WiFi and cellular when trying to connect to anything. Safari, YouTube, the App Store, I cloud... it just won’t connect to the internet on the device. I reset all network settings and get the same problem. I replaced a cracked screen, but was no where near the antenna which is under the battery. I thought maybe it was a loose connection, so I popped off the antenna connector and re plugged it back in. Still nothing.
完成的
Unfortunately, it shows 4GLTE and the Wifi network like nothing is wrong at all. It looks completely normal to the eye, it just won't connect to the internet via Wifi OR LTE4G even though it's connected. It also works as a Hotspot, which is off to me.
完成的
添加一条评论
添加你的答案
Paul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 159
