跳转到主内容
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
211 个问题 查看全部
TRUE or FALSE - Does the MBP 16'' vent out heat from the keyboard?
hello. i am noticing a lot of mixed information online about the macbook pros and if they vent heat out from the keyboard.
some people say the keyboard does vent out heat and that if you put a keyboard cover/skin on that it will eventually wear out (damage) the internal components, others say to monitor hardware temperatures if you cover the keyboard, etc.
all of this seems to indicate then that the keyboard actually vents out heat!??
but where are the vents in the keyboard then? this seems like a completely false rumor! i feel like snopes and we got to get to the bottom of this!
please help me find the truth.
thank you,
Mongo
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
No it does not, the keyboard is completely sealed over with backing foil.
https://d3nevzfk7ii3be.cloudfront.net/ig...
If you count thermal radiation, it does pass heat out a little, but that’s it.
这个答案有帮助吗?
得分 3
4条评论:
that's very interesting!! is that what they mean by the Magic Keyboard having a membrane now? did this exist in prior MBP keyboards? i wonder if this backing foil (which I originally thought was only for the keyboard backlights) can even prevent liquid damage from the keyboard!?!
Most importantly, do you think that using a keyboard skin/cover like the Ghostcover, Kuzy, etc. could cause an accumulation of heat (from thermal radiation) that can damage the internal components?
完成的
The systems active cooling is limited to the side vents for cool air and the rear for the exiting hot air.The older unibody systems leveraged some air flow from the keyboard (the ones that don't have side vents) that's what people get stuck on (older design vs new).
The keyboard height from the display and how much compression then becomes the issue with skins. The thicker ones on the Butterfly keyboard can cause issues. The ultra thin ones are OK but I really only recommend skins on the newer 'Magic' Scissor keyboard design keyboards as the key design has more travel and won't get damaged from the slight compression of the very thin skins.
完成的
@danj Thanks Dan! that's helpful.
I will probably buy the keyboard cover then from Ghostcover which is 0.12mm. I know the one from Moshi is 0.1mm, but I'm guessing maybe they just rounded down instead. Regardless, do you think the keyboard cover can scratch the screen over time from accumulating grime/dust/sweat/oil/etc. ?
Finally --- Now I'm thinking of going all out to protect my MBP 16''.
i'm thinking of getting the complete bundle from Ghostcover here: https://gouppercase.com/products/ghostco...
Of course this now includes palm rest covers, as well as trackpad & touchbar cover. Do you think this is also safe/OK for the macbook? Of note, I notice that the palm rest areas of my macbook do get warm under load currently without anything sticking over that area.
you guys are awesome. much love, Mongo
完成的
Taking the skin off and cleaning it is a good idea if you think you are getting grit and dirt on it. Don't use any spray cleaners on your system directly! Spray a micro cloth and then wipe the surfaces. or screen. With COVID running rampant seeing a lot of messed up systems from liquid damage (cleaners)
I think you are going too far, the keys yes, body (palm) and touchpad not really needed and you'll find finger tracking will be different on the touchpad. The skins won't insulate you from the heat. I would get a good thermal management app like TG Pr so you can monitor things and ramp up the fans when needed (turbo).
I would get a set of external skins to protect the outside surfaces or get a hard snap-on case. I have a upgraded 2011 15" MacBook Pro (now has a 2012 logic board) which I use for posting on iFixit and watch youtube when I'm not working (bought new). I still have the original trackpad and only were my watch strap hits is the top surface messed up a bit at the edge My newer work systems have no damage at all. Just to give you an idea how tough anodized aluminum is.
完成的
添加一条评论
添加你的答案
Mac Man 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 26
总计 917
