跳转到主内容
Repair information for Sharp televisions.
39 个问题 查看全部
Will it work by replcing a single metal dome?
Hi there,
I have recently encountered an issue with my Sharp smart TV remote controller, I managed to disassemble it and one of the mental domes was damaged, it won't bounce back up.
So I wonder if I replace just the damaged mental dome, will it working again as normal?
The thing I need to do is that peeling off the adhesive tape with metal dome on it.
Please help me, thank you very much!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
最有帮助的答案
@v3nuo take a picture from the other side and post it as well. Those “domes” look like microswitches. You would need to replace it completely to repair the remote
这个答案有帮助吗?
得分 2
评论:
Hi @oldturkey03, thank you very much for your quick reply, I have tried to peel off both the damaged metal dome and a working one, as they are completely independented, so I can easily peel them off.
I will try to replce the damaged dome with a good one, and see how's it going, thanks again for your kind reply and help.
完成的
添加一条评论
添加你的答案
Albert 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 39
