now no picture only
Yes it had the problem yesterday but it turned on eventually, today the same thing and now no picture only when i shine the flash light on the tv screen i can see pictures
jesseholt123 this is most likely a backlight fault. You need to check the power board to see if it does supply the proper voltage to the backlight array. If it does the issue will be a failed backligbt array. To help you find what you need we need to know your TV's exact make and model. Also, pictures always help. Once you remove the back caver from your TV post some good pictures of your boards with your QUESTION
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 24
