跳转到主内容
Repair guides and support information for televisions manufactured by RCA.
181 个问题 查看全部
My led42C45RQ began intermittently havinig sound w/no picture. replac
My led42c45rq tv intermittent picture, w/sound. Replaced power supply board, has 5vdc and 12 vdc on proper points on main board, etc no picture still.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @vanlewend ,
When there is audio but no picture, try shining a torch at an angle close to the screen to see if there are any images there on the screen. They will be very faint if they are there so trying this a darkened room may help.
If they are there then there is a backlight problem.
Since you have replaced the power board the problem is either in the backlight LED array or perhaps the mainboard is turning the power off to the LEDs for some reason.
Check the voltage at the LED power cable connection when there is no display but there is audio.
Just curious if the menu screens will show when this occurs?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dale Vanlewen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 64
