跳转到主内容
PlayStation 3 Slim是Sony Computer Entertainment生产的PS3视频游戏机的第二版。 它于2009年9月1日发布。
475 个问题 查看全部
My PS3 won't turn on. No lights whatsoever.
I have a PS3 Slim (160 Gb) variant. 2 days ago I ordered GTA V. When i inserted the CD everything was fine. Proceeded to installing the game and at about 50% the PS3 just shut down with no beep or anything. When I connect it to the power cable, I can't see any red light or anything. It's as if it's dead. I looked up a lot on the internet for solutions and it's not YLOD cus there's no light at all. I opened it up too, cleaned it properly (it was very dirty lol) and it still won't turn on. Can someone please help me out?? (I took my PS3 out 4 days ago. My mom had stored it in a cabinet for a couple of months)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
It is most likely a PSU failure and/or some capacitor blown.
You need a multimeter and a new PSU (like this: https://www.ebay.co.uk/p/5007142744), or if you have a configurable power source you could use it to verify that the problem is the PSU.
这个答案有帮助吗?
得分 2
4条评论:
Thanks for the quick answer.Will changing the PSU ensure that the PS3 will work fine like before?
完成的
You should try another power cable, and power outlet just to make sure that the cable isn’t causing the problem. Since there is no light or any sign your ps3 is turning on, it’s either the cable the power outlet or the PSU.
Good luck
完成的
There is no certainty, it could even be the motherboard burnt.
完成的
Does your ps3 work now ?
完成的
添加一条评论
If it’s not PSU problem.then it may be motherboard issue
这个答案有帮助吗?
得分 0
添加一条评论
i have this issue and the wifi card shorted out
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mohammed Basil 将永远感激不已
浏览统计数据:
过去 24 小时: 13
过去 7 天: 106
过去 30 天: 413
总计 8,785
