跳转到主内容
Repair guides and support for your Sanyo TV.
344 个问题 查看全部
Old 2008 to 2010 Sanyo Tv turns off on it own
My tv still works and turns on but every now and then it just turns off all by itself. We turn it back and the screen still works just turns off on its own. It can stay on for long while or for short intervals but the picture has never gone out. I’ve checked the cord in the wall and the connections on the back of the tv everything looks good. I’m not sure what it needs so it doesn’t keep doing that. Any help would be great. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
Hi,
What is the model number of the TV?
Check that any air vents in the TV back cover are clear and free of dust etc, so as to allow the hot air to escape to prevent overheating. Use a vacuum cleaner to clean them if necessary
完成的
I’m not sure. How do I check the model number? Actually I just figured it out the model number is DP32670.
完成的
No, the power in dictator doesn’t turn off. I never really noticed it but it doesn’t and the screen goes black with no audio. But I did notice that when I touch or put slight pressure on the right side the screen goes black. It might have to do with a line I’ve seeing on the screen for some time now.
完成的
@jaxlb where on the screen did you see this "It might have to do with a line I’ve seeing on the screen "? This "I touch or put slight pressure on the right side the screen goes black" of course before it goes black and no audio? Bottom right side or top?
完成的
I’ve attached a picture to my question.
完成的
显示更多的2条评论
添加一条评论
1个答案
最有帮助的答案
Hi @jaxlb ,
Does the power indicator light on the front of the TV turn off when the TV turns off or just that the screen goes black and there is no audio either?
If so it seems to be a power problem.
Disconnect the power from the TV and then remove the back cover and inspect the boards especially the power board for any signs of heat stress to the components or bad capacitors (leaky or bulging).
If you spot something or your not quite sure, post some close up images of the power board. Here’s how to do this. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
1条评论:
Hi @jaxlb,
As @oldturkey03 said a TAB problem won't make the screen go black or the audio stop.
It sounds like a power problem or the mainboard perhaps.
Here's the service manual for the TV. It has the schematics for the power board so that the voltages can be checked when the screen and audio are no longer there but the power light is still indicating that the TV is on (see p.12 in the manual.
As I suggested in my answer above check the power board (it's the board where the power cord from the wall outlet connects to inside the TV) for any obvious signs of component stress and post the images back here.
Be safety aware and disconnect the TV from the power before working in the back of the TV except when testing the voltages of course;-).
完成的
添加一条评论
添加你的答案
Juanita 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 373
