跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
467 个问题 查看全部
Can the front facing microphone, for Siri, be replaced.
Siri stopped working and I tried turning Siri off and back on. I wasn’t able to go through the “hey Siri” setup. It had images of noise while nothing is said. I tried a front self video and the sound is scratchy. I have also tried a full restore and reload…. after tapping on the microphone at front camera, it is working now but I’m sure it will quit again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi yes, the microphone is replaceable however I believe you need to desolder and solder a new one on. If you want to replace the whole front assembly then Face ID will no longer function. If I remember correctly only swapping out the microphone won’t affect Face ID.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Barry Richardson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 73
