跳转到主内容
Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
493 个问题 查看全部
Found gas in the oil
I used my golf cart on the golf course several days ago and it was running fine, I went to use it again and it would not run. Upon inspection I pulled the oil filler tube cap an noticed it was about to overflow with a mixture of oil and gas. What are my next steps to getting this repaired?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Take carburetor off and fix stuck float valve and also check the electric main jet cutoff valve if so equipped and make sure it is functioning correctly. Drain oil and add fresh oil and filter. I would also check the fuel system and make sure the gas cap vent is not obstructed somehow.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Randy Elling 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 72
总计 918
