Water damaged and it won't start.
MacBook Air 2013, would not start, took it apart, dried out water and cleaned solder points with isopropyl alcohol 99%U.S.P., tried restarting it and it started once, but computer screen wasn’t working, worked with a monitor connected, shut it down, charged it overnight, it won't start now. Any ideas?
3条评论
Thanks Zachary.
Since I wrote about the problem above, I have been able to start the computer again. To start up I had to disconnect the battery connector ribbon and have the the power supply plugged into the computer. I am unable to use the computer’s screen, no response from it and can see as long as I am connected to a tv set. I ran Disk Utility/First Aid and there were no errors found.
由 Jack Greenwell 完成的
Thanks, Chris, I gave that a try and with the light shone through the Apple logo I was able to see a bit of the computer screen and whatever was occurring at the moment.
When I am using the computer and I accidentally hit the power key the computer immediately shuts off, even if the battery is connected.
@jake45 It would be best to address the backlight issue first.
由 Chris Stables 完成的
