跳转到主内容
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
93 个问题 查看全部
Why won't my Jeep start and why is it through gauges?
My Jeep won't even begin to turn over, behind the instrument panel there's a clicking and all of the gauges go haywire when I go to turn the key. Replaced the starter 5 months ago, battery is 2 years old and I just had it tested all good. I'm pretty mechanical and have checked the grounds for the engine and to the starter but can't for the life of me diagnose this... Any ideas??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The instruments going haywire and not starting is a sign of low voltage.
You can get low voltage from either a bad battery (yes, its new, but they do go bad on occasion - have it checked before the warranty runs out). With electrical gremlins, battery is ALWAYS the first place you check. Nice clean connections!
The other cause of low voltage is a bad ground. The instruments (and most of the stuff behind the dash) hook to a ground wire that is actually under the center console, near the parking brake. I did a complete dashboard removal and forgot to tighten that nut …. worked for a while and then one day it went nuts. (AC, overhead console, gauges - but the motor would start).
这个答案有帮助吗?
得分 1
1条评论:
yes!!! I did a heater core and a week later another heater core cause the first one was leaking. neglected the ground wire on the second install and the dash went crazy when the AC was turned on or the headlights were . one little nut tightened down solved it all. thanks for posting! it was a lifesaver
完成的
添加一条评论
添加你的答案
Sam Bragg 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 14
总计 183
