what's inside or pizza any1
i’m starting from scratch. I need to add a drive now. how do I “get in”?
Here’s the guide to add a drive (2nd) Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive I personally don’t recommend it! The Optical drives I/O is a very slow PATA connection ATA/100 (800 Mb/s). If you are thinking of adding a SSD you’ll be wasting it as the interface limits it.
The better direction is to replace the HDD iMac Intel 20吋“EMC 2133和2210 硬盘更换 with a better drive. We still have an issue with this systems SATA port as its only SATA II (3.0 Gb/s) most SSD’s today are SATA III (6.0 Gb/s) and won’t work well in your system. You’ll need to find an older fixed speed SATA II (3.0 Gb/s) drive or a auto sense drive which will match the systems I/O speed. Review the drives spec sheet to make sure it lists SATA II if it doesn’t then its not able to support the slower interface.
指南
难度:
中等
1 hour
指南
难度:
中等
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 42
1条评论
I should have waited. I'm inside it now but lost video.
由 James Walker 完成的
