跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
677 个问题 查看全部
Bottom left of screen turned grey/black after the screen replacement
I bought a cheaper iphone8 plus with shattered screen . I was hoping to fix the screen and start using it. I replaced the broken screen with the new one. When I turned on the phone, the bottom left of the screen turned greyish/black. I thought that it must have been the circuit problem. I uninstalled the screen and reinstalled it but it still the same. Old screen didn’t have that issue. What could be the problem. Please help. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Do you still have the old screen at hands? connect the old cracked one again and see if that has the same problem. If the old one works fine you simply got a bad display from your supplier, unless you damaged it during the repair.
这个答案有帮助吗?
得分 0
1条评论:
No I do not unfortunately. I threw it away. I don’t think that the display has gone wrong. I installed another Logic board in the phone using the same display and it works fine. Could it be the motherboard?
完成的
添加一条评论
添加你的答案
shanparshan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 93
