跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
What tools do I need for repairing fpc connector
Hey All,
I was wondering if someone here could help me get started with microsoldering and help me find the tools I need. I have been able to get my on a lot of ipads and iPhones which couldn't be fixed in a center (they didn't do soldering repairs) so I want to experiment with them.
Any help will be greatly appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I assume this is the digitizer FPC touch screen connector right?
You’ll need the following:
  • Soldering iron
  • Fine pointed tweezers for pick up and placement of the old/new FPC connector
  • Solder wire (leaded of course is always better, non leaded has a higher melting point making it harder to use)
  • Hot air rework station: A good quality one goes a long way, the cheap ones may not provide enough heat or constant temperature to remove the old FPC connector quickly and easily.
  • Flux: AMtech NC559-V2-TF (doesn’t have to be exact there are similar models that are good) is what I use. Cheap flux may not let the solder flow well with solder joints, pads or connectors and can increase the chances of solder bridging.
  • Solder Wick: To remove old solder mostly for non-leaded solder to put in place leaded solder.
Note that the FPC connector is quite fragile where some pins may break off when unplugging the digitizer ribbon cable. To avoid this always unplug from the shorter end with nail or a flat rigid spudger (nylon plastic types will do).
这个答案有帮助吗?
得分 1
2条评论:
@benjamen50
Yea indeed.
Do you have any suggestions for a decent soldering station and m hot air station?
Thank you for your help
完成的
Quick 861DW for Hot Air Station and Hakko FX-951 these are quite expensive options there may be cheaper alternatives.
完成的
添加一条评论
添加你的答案
Jochem Luytens 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 702
