My daughter hit TV with sharp object
Hello,
My daughter hit my TV yesterday with sharp object and I see the vertical lines like below:
could you please recommend if it can repaired?
Hi @gkrishna25 ,
The screen is cracked and will have to be replaced as it cannot be repaired.
You can try searching for a replacement screen either by searching for the TV model number or the panel number found on the back of the screen itself, but don’t be surprised if you can’t find any or if they cost nearly as much as a new TV.
The option then is to advertise your TV as faulty screen - good for parts to try and recoup some of the cost towards a new TV. Working TV boards are always in demand
这个答案有帮助吗?
Thank you!. I do not see any crack on top of the screen(where I put my finger) may be there is another scree beneath that cracked. My TV is Vizio eos m55.
Where can I advertise? Could you please tell much does Best buy pay for it.
Best Buy will just recycle it. Try Craigslist and other similar sites.
It looks like an internal crack in the panel itself. It happens
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 1,179
