It will not get channels I have cable from wall
My TV has only one channel i tryed everything
Hi Kiana Flores
It would be good to share where and which country you are located, so
Just to check when you do a full channel scan, it only show one channel? how about other tv? had you test the outlet with another tv?
https://www.manualslib.com/manual/169081...
In rare case if the tuner could be faulty and the hdmi ports are working well, you can consider getting a set top box to receive channel and connect to hdmi port
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 59
