Why is my switch draining faster than it charges?
So I recently replaced my switch’s battery thinking that was the issue because it wouldn't charge or turn on while leaving it. When I received the new battery I noticed the switch turned on and as well as charged. I did some cleaning up and all of a sudden my battery was at 20% with the charger being in the console (OEM charger). I have no idea what It could be, I tried moving the batter to another switch and it changed correctly.
Could be a bad battery or you have knocked something of the board during the repair
由 Zaheer Patel 完成的
So I tested the battery on another switch and it charges fine and works as intended. Prior to putting in the new battery on the switch, the old one wouldn't even turn on and I'm guessing that had to do with the same issue of not taking sufficient charge to even power on.
由 Edison Cartagena 完成的
