wont turn on after diy repair
after replacing screen myself Iphone speaker was not working so I was going to check the #3 connection and forgot to turn off the iphone before taking apart. checked all connections multiple times, have waited 5 mins for reboot several times. Did I fry the iphone by not turning it off before taking apart? IF so can I fix it?
4条评论
I also have the same problem. I repaired my iPhone's cracked screen and after reconnecting everything it wont seem to turn on. I thought I might have broken the LCD but even if it were broken it would atleast glitch or something
由 pillsburyboi 完成的
hey, i did tear down too of the top glass part on my iphone 3g and once i put everything back together, i couldn't turn the iphone on (or it seemed that it was off). But once I plugged in to charge it, the screen started working. What could be the reason? Thanks..
由 vik 完成的
this is a very common question, and i have yet to find a detailed answer on this website. Everyone seems to ignore it, and it's torturous because i have the same problem. Repaired everything fine. Connectors are in place...phone's display will not work. Itunes charges the phone, and I can toggle the vibrate/ringer switch to make the phone vibrate...but that's it. PLEASE HELP! Many people have asked as i've searched for this for hours upon hours.
由 Taylor Jones 完成的
is the phone actually charging? if not, then there seems to be a connection problem. Try and see if the battery is actually connected. Tell me what happens after you do that. Let me help you
由 Trey Dollarz 完成的
