Just to add a note to this category of Display swap for anyone else who is wondering about compatibility:
I just swapped a MacBook Pro 15" late-2008
Glossy Screen Display Assembly
with a MacBook Pro 15" 2009
Anti-Glare Screen Display Assembly
So what I mean is, I have swapped the WHOLE top case Display assembly, and they match up in the following ways:
Hinges = Perfect match
Cables = Perfect match
Webcam = Works
Display + Brightness Control = Works
Airport = Works
Resolution = Same as before 1440 x 900
(I am NOT using a high-res anti-glare, just a normal res anti-glare)
Bluetooth = CANT GET IT TO WORK
The Display Assemblies are almost identical matches with the exception of the Bluetooth card.
It seems that Apple stored the bluetooth card for the Glossy / Glass screen MacBook Pro under the glass at the bottom of the display, however the Anti-glare screen has the bluetooth board attached to a cover near the display assembly hinge on the underneath of the laptop.
This bluetooth board cable runs into the normal Display / Backlight cable which plugs in fine to the logic-board, however the bluetooth board is attached to a cable cover which has different screw + position holes than the original 2008 MacBook Pro 15" case has, so it won't marry up.
I have simply re-used the original cable cover from when I swapped the Glass / Glossy screen over, and unscrewed the bluetooth board from this and taped it down to the DVD drive underside, but the Bluetooth does not work in OSX ?,
also, there is no antenna cable for it, so even if it did work, I expect that the reception might be very very poor.
- Hope this might help if people are reading this thread and wondering about the Glass to Anti-Glare Display Assembly swap?
^_^
2条评论
Michael did you get any joy?
由 ABCellars 完成的
Did it work?
由 bier1616 完成的
