跳转到主内容
Why won't my speaker turn on?
I have a shower speaker which will not turn on. Whenever I charge it It shows that it is charging but it never finishes. The Led light always remains red. When I do attempt to turn it on the device is unresponsive and the blue led light doesn’t show. It didn’t start this until recently. Could someone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi there,
The power switch may be the issue, it could be the switch itself or cold solder joints on the power switch. If it has a sliding on/off switch the little arm on the switch could be broken meaning the part you slide has nothing to catch on to to move the physical switch to the on position.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for your reply but my device doesn't have a switch just buttons. I tried to put a picture but the resolution was low.
完成的
If you can I would open it up and have a look at the power button, if you have a multimeter you can check the continuity of the button.
完成的
添加一条评论
I had the same problem. I had to lift u other middle part where the cover with all the symbols are on it. Once you do you will see the circuit board, look around the edges to see if there is corrosion if so take a cotton swab and vinegar, or water and baking soda, to remove the corrosion. Should work fine after.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jay Jackson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 1,975
