跳转到主内容
Repair guides and disassembly information for the 2017 edition of Razer's 14-inch Blade gaming laptop.
15 个问题 查看全部
Thermal throttling and overheating
After a few years of use my Razer Blade laptop has started overheating/thermal throttling reaching the high 90’s Celsius. I figured the stock thermal paste needed replacing. After replacing it it still is thermal throttling and reaching high temps when using demanding programs. Never had issues with temps until now. Temps would range mid 60’s to mid 80’s while gaming depending on the game. I’ve even undervolted the processor but that doesn’t make any difference. Both fans run at max speed while gaming, both inside and out are spotless. I’m at a loss as to why it continues to overheat/throttle after applying new paste.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well, did you clean out the fans/heatsinks? If those are clogged, then it’ll still prevent proper cooling.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dustin Salerno 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 752
