跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
My MacBook's display blacked out suddenly. What to do?
My MacBook was on a table playing some music from Spotiy when It's screen suddenly became black.
Initially I thought it has gone to sleep but when I tried to turn it back on by pressing some keys and using the trackpad it didn't wake up.
I the keyboard backlight was on and the music was still playing and stopping when I pressed the space bar.
So I searched online and found a test of backlight. I turned on my phone's flashlight and pointed it to the translucent Apple logo and I could see central part of the screen light up slightly.
it is a backlight problem. Backlight is probably not getting power. But why?
There's no Apple service centres nearby and I don't have Apple Care+. If anyone can help I'll be thankful for him/her.
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Usually these faults are caused by liquid damage which may require micro-soldering to fix.
If it is a no backlight fault there should still be a distinguishable image but very dim around where the apple logo is on the screen.
If you can’t see it try holding the power button for about 5-10 seconds to force turn it off and turn it on again and repeat the flashlight test. If no apple logo / sign in / loading bar is shown then there is a no-image fault. Probably not the screen but something to do with the display circuitry on the logic board.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for answering.
I tried this flashlight test and yes I'm seeing the Apple logo and the sign in and then my desktop too.
I'm sure that the backlight is not getting power.
Do you've an idea why did this happen? Or how can it be repaired? What will be the cost?
完成的
@kunalmishra Ok that confirms that is a no backlight fault.
This occurs 99% of the time due to liquid damage.
What's very common is that the backlight driver chip under the logic board gets liquid damaged which stops the chip from working and that chip would need to be replaced via micro-soldering and any other corroded components as well.
There may be other sections of the board that also has some liquid damage / corrosion. The cost of these repairs generally start from around $200 as an estimate.
完成的
添加一条评论
添加你的答案
Kunal Mishra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 40
