跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 个问题 查看全部
Diagnostic LEDs OK but no power
My customer's iMac is not booting at all. When the power button is depressed, the optical drive makes a sound as it resets the optical part, diagnostic LEDs 1, 2 and 3 light up (the LCD is currently disconnected), and nothing else happens. The hard drive does not spin up, no fans start, nothing. I've tried starting it in Firewire target mode but that doesn't work. I tried resetting the PRAM and the SMC, but no results. The customer took it to the Apple store and they determined that the logic board and power supply must be OK, probably based on the 3 diagnostic LED's and said it was most likely the LCD. I don't buy that. Even with the LCD disconnected, I think it should be booting. Am I wrong about this? When searching the Interwebs, I can't find any pinout voltages for the power supply so I don't know what to test for there. Any ideas based on your experience?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hook up an external monitor to help isolate the problem and let us know your results.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
powerbrixx 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,176
