跳转到主内容
Repair guides and support for your Philips TV.
237 个问题 查看全部
Why is "Channel up" on my TV remote jumping to channel 700 when press
Every time I press “channel up" it jumps to channel 700 (radio) regardless of what channel I start on. If I continue pressing it after that, it scans up as normal, until it reaches the first TV channel, and then it goes back to channel 70/ again. I have a 10 month old daughter, so I suspect she's pressed something on the remote. Everything else works fine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi,
What is the model number of the TV?
完成的
添加一条评论
4个答案
已选择的解决方案
Click ‘List’ (the button symbol is three horizontal lines, kind of like a cheeseburger symbol). Change the setting in the drop down from ‘Antenna Radio Channels’ to ‘All Satellite Channels’
这个答案有帮助吗?
得分 6
添加一条评论
I found an answer, on my Mum's TV remote there is a language button, pressing it brings up the word English on the TV, pressing OK brings up a menu that defines the channels for the channel up and down buttons. Who knew that was there! It is very well hidden.
Once I found it fixing it was simple.
这个答案有帮助吗?
得分 3
6条评论:
I've been pulling my hair out for weeks and you've only gone and sorted it for me, I would never have found that, worked 1st time, thank you so much Mandy.
完成的
It's a terrible design to put that menu item there, glad you are fixed now.
完成的
Thanks, you have given me the answer too
完成的
Glad you are fixed too.
完成的
Thank you - one of life’s frustrations sorted 😎
完成的
显示更多的1条评论
添加一条评论
Thanks this helped for my Sharp Aquos Smart android TV, I had the same. Whilst in a TV or radio channel press MTS > language displays e.g. English > press ok then hit < left or right > until you see “all channels” at the top of the panel.
这个答案有帮助吗?
得分 2
3条评论:
I have a Toshiba TV SUAZBe3DB and I have the same issue. Any tip please?
完成的
I also have a toshiba and have the same issue, please help!
完成的
I also have a Toshiba TV (only 2 months old) that's decided to do this, it's going through the window if I can't sort this, any help would be massively appreciated
完成的
添加一条评论
Channel changers generally have a favorites position. It may be in that mode now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David James 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 73
过去 30 天: 339
总计 10,024
