跳转到主内容
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
66 个问题 查看全部
RTC mode fixed -Time and date may be wrong
When I am power on my dell inspiron 1545 it shows “RTC mode fixed -Time and date may be wrong
Invalid configuration information -please run SETUP program
Internal hard disk drive not found
To resolve this issue, try to reseat the drive.
Time -of-day not set-please run SETUP program
Strike F1 key to continue, F2 to run the setup utility
Press F5 to run onboard diagnostic.
Plz help me from
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Thr RTC battery in the laptop needs to be replaced.
This battery maintains the BIOS settings when the laptop is switched off.
When it has failed the BIOS can become corrupted which prevents the laptop from starting properly.
Here’s the service manual for the laptop. Click on Coin-Cell battery in the Contents section to view the necessary pre-requisite steps and then the procedure to remove/replace the battery.
The battery is a non rechargeable Lithium battery, usually a CR2032 (battery type is printed on the battery)and lasts ~5 years. It is commonly available, even supermarkets sell them.
When removing the battery remember which way it was installed (usually +ve on top) so that the replacement is installed the same way.
When the new battery has been installed, when starting the laptop, press F2 to get into BIOS and correct the date and time. Also see the instructions in BIOS how to set the BIOS to the default settings (usually it is F9 but may be different) Whatever it shows, reset the BIOS to default and then save the changes, and restart the laptop.
Hopefully it should be good to go.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Fahmi Daanish 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 44
总计 5,196
