images and graphics discolored
I have searched and searched the internet for an answer to my problem. I've hit the tablet. I've tried to flex the tablet…nothing helps. I've disconnected the lcd and reinstalled it. Still same issue.
The issue is this: everything looks fine on it except for any image or graphic. So the menus look perfect and regular icons look perfect. However any image looks like a negative. I've tried resetting all the settings. I've went thru it and made the settings look just like another air 2 that i have and can't figure it out. I at first thought the lcd needed replaced but there are no lines in the screen or any fading in certain areas. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Have you tried replacing the LCD yet? You won't know if it's a bad screen unless you replace it.
完成的
No i haven't. I didn't want to spend the money on one if someone thought it could possibly be something else.
完成的
添加一条评论
