跳转到主内容
所有的苹果便携式平板电脑的全面维修手册。维修过程可能需要加热以及细心的撬动。
5709 个问题 查看全部
iPad port charger is lose how do I fix it at home?
My iPad port charger is lose how do I fix it at home ?? Help me plz
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Check and see if it has lint stuck in it and try to clean it out. If that doesn't work you will have to take it apart and solder on a new charging port and you will need the equipment and skills to do that. You can also have a local repair shop that does microsoldering repair or you can Mail it in. I recommend jessa at ipad rehab ipadrehab.com or Jason at sts telecom ststelecom.com both are excellent and you can watch there shows on YouTube.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aalia Erby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 102
