跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
White screen - SSD upgrade no luck - maybe GPU?
After my mac white screen’d I tried all sorts of recovery, no luck, it just boots to white screen before any recovery tools (disk util etc) show. Diagnostics gave me the error code: 4mot/4/40000003:hdd 1226 - which I researched was most likely the HDD fan.
I took it to the Apple store and they said they think the HDD needs replacing but since it’s a legacy product I’d have to do it myself, I questioned whether the HDD had broken since I’d managed to access it fine in Single User Mode, but I figured they know more than me.. I installed a new SSD upgrade in last night…
I’m still getting a white screen, I’ve tried to run online recovery mode to format and install the OS but after it downloads successfully it just white screens halfway through the apple loading screen, so I can never get to disk utility or installing the OS.
I’m starting to wonder whether it’s my graphics card, but nothing came up in the diagnostics test for my GPU… What else could it be? It doesn’t seem like a broken fan would stop it booting.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Let's verify if the discreet GPU has failed. Restart your system and press the T key to enter into Target Disk Mode. Your screen should show either a FireWire or Thunderbolt icon floating. If you do you know the intergraded graphics is working!
Its best to use a USB keyboard. Let us know how it goes!
Reference: Mac startup key combinations
完成的
@danj yes I see the icons. Is there anyway to verify the gpu card is working/broken?
完成的
添加一条评论
1个答案
At this point you should be able to boot up in Safe Mode as well. Restart again this time pressing the Shift (⇧) key.
Doing the Target Disk Mode first resets the SMC latch which is set when the Discreet GPU fails.
Sorry to say this is not uncommon in this series when the Discreet GPU fails. You might be able to get a few more miles out of it by baking the board in an oven or just replace it.
Do keep in mind its a big job as you’ll need to take the logic board fully out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ash Lewis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 105
